Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-07-2007, 02:15 PM
gat1954's Avatar
gat1954 gat1954 is offline
Smile P0 300 Code
I had the above error in my Astro van 1996 Vortex 4.3 L
I simply looked under the Hood, while soembody was cranking,,,and Noticed sparks coming out of the Coil Pak, or Coil Wire.....
Wished the Codes, would detail problems,,, but we got her Fixed
Replaced Both,, and back on the Road..... smooth again 78K Miles
Gary
San Diego Ca November 2007
Old 11-08-2007, 11:20 AM
gat1954's Avatar
Smile P0 300 Code
I like to always report what the Problem,, and SOLUTION was in all events to Help others on the Forum ....
I had somebody, Turn the Key start, while looking at the Ignition system,, and we saw High Intensity sparks jumping around the COIL,,
The COIL, on the 1996 Astro van,, 78,000 Miles and Coil wire were replaced,,and that Solved it..
Novemeber 2007 San Diego California ((surviving after the Fires..))
still getting an intermittant hesitation once in awhile,, might be time tochange out all the Spark Plug wires,, and Plugs..
Old 11-08-2007, 04:27 PM
old_master's Avatar
Advisor/Moderator
Re: P0 300 Code
Originally Posted by gat1954
...Wished the Codes, would detail problems,,, but we got her Fixed
Gary
A good scan tool will tell you what the codes mean right on the readout screen. This site has the descriptions of each code: http://www.obd-codes.com/index.php
Old 01-28-2008, 04:16 PM
once a gunner once a gunner is offline
Re: P0 300 Code
I have the same code reading....I've replaced the coil, cap and rotor haven't changed the wire yet. what else could it be?
Old 01-28-2008, 07:34 PM
old_master's Avatar
Advisor/Moderator
Re: P0 300 Code
Welcome to the forum!
To reduce the possibility of confusion, it would be best to start a new thread here: http://www.automotiveforums.com/vbul...ewthread&f=117 Post the symptoms, vehicle data, and what you have already done, and someone will help you. Thanks!
Closed Thread
