Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-07-2007, 11:38 AM
evildragon evildragon is offline
scent of gas
This is two times in a row I've noticed this (then again, this is two times in a row I had my windows down cause it's nice outside).
I start the car, idle feels "rough", I go into reverse and pull out, and as im pulling out, i smell gas.
What's up with that? I don't see any obvious leaks.
My one and only car!
1994 Chevy Caprice Classic LS
L99 Engine
Old 11-07-2007, 01:05 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: scent of gas
Check for vacuum leaks or bad hoses on everything that attaches to the vapor canister. Make sure the purge valve is intact and operational.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-07-2007, 01:52 PM
Re: scent of gas
Well, the purge valve, that's just dangling, it lost it's clip to the engine, is that ok?
L99 Engine
Old 11-07-2007, 01:58 PM
silicon212's Avatar
Confoundingly Lucid
Re: scent of gas
As long as the lines are attached correctly, no problem.
Old 11-07-2007, 02:04 PM
Re: scent of gas
Ok. the lines are attached, and I zip tied it to another line, to make sure it never goes anywhere.
this scent is only when it's cold in the morning, if it's hot in the morning, there's no smell either.
L99 Engine
Old 11-07-2007, 05:09 PM
silicon212's Avatar
Confoundingly Lucid
Re: scent of gas
There is a small filter on the bottom of the canister - this might be plugged. It's replaceable and they're not expensive - that may be the problem.
