Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 11-07-2007, 11:19 AM
ridgeinsp ridgeinsp is offline
Del Sol door handle problem
My 96 del sol driver side door handle seems to be disconnected. Can't get into the car once the door is closed, as the handle is all floppy.
Is there something I can do, or do I need a mechanic? Is the door panel hard to take off and put back on?
Was just wondering if this is a common defect or not.
Tx.
Ridgeinsp
Old 11-07-2007, 11:33 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: Del Sol door handle problem
It might just be disconnected. Removing your interior door panel isn't really hard. 1 or 2 screws and then just pull. It's mostly held on with clips.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 11-13-2007, 09:46 AM
bLacK_mOua bLacK_mOua is offline
i got the same problem with mines. i popped the panel and unscrewed the door handle. there's a spring hooked on behind the handle, either that's loose or the plastic piece that holds it broke off which is what happened to mines, and I lost the spring. I'm ordering a new door handle...i'll let you know how it goes once i get it.
Old 12-20-2007, 01:21 PM
Yup, got it done and it works better than before.
Old 01-28-2008, 11:42 PM
45slade 45slade is offline
I had the same problem on a 93 I just purchase a month ago. Had to remove the door panel to get the outside latch removed. The linkage has a pivot pin pressed into the latch body. The pivot pin had siezed and the operation of the latch had torn it out of the latch body. Left everything flopping around.
Lubed and freed up the pin and then Gorilla Glued it back into the body. Re-installed and re-assembled in about three hours (giving the glue enough time to set).
