Old 11-07-2007, 09:31 AM
agape agape is offline
95 Windstar uneven break pad wear
My 95 windstar wears out the passenger side front pads while the driver side pads are still good. The driver's side caliper works when pedal is pressed and there is no visible caliper leakage. Could there be interior leakage in the caliper causing the problem? Could the proportioning valve be the issue? The car has 195,000 miles on it.
Old 11-07-2007, 04:32 PM
phil-l phil-l is offline
Re: 95 Windstar uneven break pad wear
The caliper pistons on that side are probably sticking. No leak required to cause this problem - it's just the caliper continuing to put pressure on the pads after the brake pedal has been released.
Replace the caliper. Personally, I'd replace both sides if you're planning to keep the vehicle: The other side is probably close to failing as well.
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 11-07-2007, 07:01 PM
kahjdh's Avatar
kahjdh kahjdh is offline
If that doesnt fix it your flex/rubber line could have collapsed on the inside and leaves the caliper piston slightly engaged.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 11-09-2007, 12:28 AM
searcherrr searcherrr is offline
Send a message via AIM to searcherrr Send a message via MSN to searcherrr Send a message via Yahoo to searcherrr
Exclamation Re: 95 Windstar uneven break pad wear
I had a bad proportioning valve (once) and bad rear wheel cylinders (twice) at 85k and 131k miles. I didn't do the work so I hadn't seen if the pads were unevenly worn, but on another vehicle my pads in the rear only were unevenly worn and I have to replace the prop valve soon cause EVERY other brake part on the brake system has been replaced with new parts. It is the only thing left on my car that could be the culprit to the uneven wear on the rears and the lack of stopping power.
Also, I replaced my front calipers a while back after 131k too. I have gone through (attempted) the rigors of rebuilding a caliper and I can tell you I just is not worth it at all. For your time and effort it is too complicated and mostly too hard to get as clean as you need to get it. I'd replace the two front calipers just for the hell of it ESPECIALLY at 195k miles!!!! MAN I'm surprised they are still working !!! Definitely FLUSH the system thoroughly too. If that doesn't fix your problem I'd look at the prop valve and/or rear wheel cylinders for leakage anyway.. I'm pretty certain the cylinders will be leaking. CHECK the rear cylinders etc.. for leakage before you open the system up.... before the flushing etc... such to not waste brake fluid... cause if you do have leaks in the back (which I'm pretty sure you will have) you need to fix that anyway. Maybe you'll be lucky about not having rear leaks or bad prop valve, but I'd be surprised.
You should also check at this point to see if your rotors are still within OEM spec width (need a micrometer for this and the spec width of course).. if they are original rotors I am willing to bet they are beyond gone. This could also be part of your problem. I'd definitely check the condition of the rubber brake lines too. If cracking... replace.
Also, FYI - I have a 95 like you.... we seem to be RARE. lol
1995 3.0L 3000GT NA FWD ATX - ProwlerGT on 3si.org
1995 3.8L Ford Windstar GL
"I drive the newest 1995 Ford Windstar anywhere..... when its not broken."
