Old 11-07-2007, 09:26 AM
rocco666 rocco666 is offline
help with squeeky serpenten belt
I have a problem that has stumped all the mechanics and shops i have brought my sons 98 blazer too. The problem is a squeeky serpenteen belt... now what we have done so fr is changed the idle arm, the belt tensioner, the belt, what happens is we change a part and it seems to not squeek but if it sits for awhile when started the noise returns. The squeek started when we had some ac work done to the vehicle,,, new compressor, and evaporator and so on...... ever since then the belt has been squeeky,,, has anyone ever had this problem...... please help asap ,,,,,
Old 11-07-2007, 05:57 PM
gserve gserve is offline
Re: help with squeeky serpenten belt
Try a Goodyear Gatorback belt. It worked for me.
Old 11-07-2007, 06:28 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
I had the same problem with my 2000 Jimmy SLE 4.3L. I tried replacing eveything too, including the Tensioner and idler pulley but nothing worked, the squeek kept returning. Luckily, I was able to return the parts that didn't fix the problem. The Gatorback was my latest try and it is working so far. None of the other brand name belts seem to hold up.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 11-07-2007, 09:35 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
First, this may sound dumb, but make sure the belt follows all the groves on each pulley. It may sound dumb, but its easy to oversee this. Next, since you mention the noise started when there was A/C work done on it, check and makes sure all the pullies are aligned to each other. In this case, closely look at the compressor, and make sure its aligned properly. Is the belt jumping any of the pullies? Check the belt routing and see what you get.
Old 11-08-2007, 10:18 AM
Rick, when did u install the gator back belt,,,,,,,,how long has it been on and is it still ok
Old 11-08-2007, 10:19 AM
The belts I have installed have not jumped of or been damaged...... but I will check the allignment of the compressor anyway....
Old 12-14-2007, 09:21 AM
blazinman08 blazinman08 is offline
i had this same problem and i tried everythinG you have and what it turned out to be was the waterpump was going bad which caused a belt squeking sound i replaced the water pump and it went away
