Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 11-06-2007, 11:22 PM
MXlonerider's Avatar
MXlonerider MXlonerider is offline
Send a message via AIM to MXlonerider Send a message via MSN to MXlonerider Send a message via Yahoo to MXlonerider
Rear tire slant
Hey all,
Well, I left the Dodge forums after trading my old '88 D100 to my younger brother, now I'm back after having recently purchased a 2000 Dodge Dakota 4.7L Auto/ 4x4 Club Cab.
When I bought the truck, it had nearly-new tires on, which pleased me. Now, after having driven a couple thousand miles, I've noticed that the rear tires seem to be wearing very unevenly. Now, I'm not sure whether this is happening on just one or both rear wheels, as I've had the tires rotated since I bought it and had a front end alignment done (and my eyes aren't good enough to tell straight from crooked sometimes), but I know that at least one of the rear wheels is riding with the top slanted out just a bit. This is causing the outer edge of the tire to wear very quickly, and I'm worried not only about tire lift, but also about losing traction and wearing something down in my rear end.
Can you list some possible causes I should look into? I'd appreciate it very much all.
OH! and one last thing--does anybody know of a place where I can get a cheap replacement stock driver-rear fender flare for this truck? Haven't had it a few months and somebody already backed into it....
Check out and rate my vehicles at My CarDomain
2000 Dodge Dakota, 4.7L V8 Auto 4x4 Club Cab Beauty
2002 Hyundai Sonata, I4 5 speed (Gone)
1988 Dodge D100 Pickup, 3.9L V6 Auto (Gone)
Old 11-09-2007, 03:54 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Rear tire slant
Welp I'm a Dodge newbie too, but angled rear tires are not a good thing. Take a good look at the tires from the rear and use a plumb-bob to check their angle. Do both tires lean the same way? Or just one? Both would indicate a misaligned rear axle and will need a 4-wheel alignment. One means that you've got a bent axle carrier and ought to get that fixed quick. Maybe your missing rear fender flare is part of the reason the wheel is cocked...due to damage of some sort to that corner?
Other possibilites are that the axle just needs to be realigned for thrust (making sure the axle is perpendicular to the centerline of the truck). This condition results in the truck "crabbing" to one side, causing the driver to steer in the direction of crabbing and causing extra wear on the outside tread, along with extra wear on the CV joints and U-joints. Not checking where the tires were rotated from makes it harder to pinpoint the problem area.
Sorry if this isn't very pointed, but keep on feeding info and we'll do what we can. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 11-10-2007, 06:10 PM
wayneo69 wayneo69 is offline
Re: Rear tire slant
maybe a bent axle or housing the rear alignment is not adjustable could be that it was wrecked and the frame is bent you can put a 4 wheel alignment on it and get the readings on the rear(that are not adjustable) but you can use those readings to start from. put it on a lift and run it in gear and watch how the wheel runs may be a bad belt it the tire then swap that wheel with a front one (just rotate the tires and run it again on the the lift and watch it
Old 11-11-2007, 08:02 PM
Re: Rear tire slant
Hey guys, thanks for the input.
I took the truck by a local shop that I trust. According to their opinions, the degree of wear shown on the tires could not possibly be caused in such a short period of time, even by a bent/wrecked rear axle. They believe that the previous owner simply never rotated the tires and needed a slight alignment, causing the very uneven wear over who knows how long a period of time. I knew it was possible... but didn't personally think there was anybody who didn't at least rotate their tires regularly over a period of years still out there. I = wrong, apparently.
Also, they said that the 4x4 Dakotas with the fender flares are built and designed such that when you look at them from the rear, there is actually a slight optical illusion which causes the tires to appear slanted. Go figure.
