Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 11-06-2007, 06:04 PM
kyle712 kyle712 is offline
Send a message via MSN to kyle712
92 sinbird overheating
i just bought a 92 sunbird with a 2.0 and was told it has a plugged rad which it does not appear to it seems to be flowing fine and it takes awhile to heat up and today after running for about 45 minutes it got a little above the half way mark on the heat gauge and the fan did not come on so i unplugged the temp sensor and the fan did come on,
did i maybe not let it heat up enough for the fan to kick in or do i have something wrong and where can i start looking
thanks
Old 01-25-2008, 06:17 PM
anomaly_va_1976 anomaly_va_1976 is offline
Re: 92 sinbird overheating
Do not know normal gauge readings for this particular car, but it might be worth your time to invest in a radiator cap... very common for the rubber seal on the cap to go bad... $5 and 5 minutes can save a big headache....
You may have two sensors... one that is a switch for the fan relay and the other to work the gauge..... check to make sure both are operating properly...
Don't Worry What Others Think -
They Don't Do It That Often!
James Collier < [email protected] >
1992 Chevrolet Cavalier Z24 Convertible (3.1, 5-sp) *** FOR SALE -- SEE CAVALIER CLASSIFIEDS ON AUTOMOTIVE FORUMS.COM***
1993 Chevrolet Beretta (3.1, 3-sp auto)
1995 Mercury Marquis (Taxicab, i.e., breadwinner)
Old 01-25-2008, 07:14 PM
inafogg inafogg is offline
hi yes u should of waited a little longer i'd replug sensor & wait until it gets above 3/4 but should kick in before...good luck
Ohh...just noticed old post
