Old 11-06-2007, 01:45 PM
Sdsand32885 Sdsand32885 is offline
99 Astro Whistles when i accelerate
I just bought an Astro like 5 days ago for work and now its making a whistling noise when i accelerate. It goes away almost immediately but i dont know what it is and dont know much about cars. Can someone tell me what it could be.
Old 11-06-2007, 02:21 PM
old_master's Avatar
Advisor/Moderator
Re: 99 Astro Whistles when i accelerate
Welcome to the forum!
Noises can be difficult to identify, and to pinpoint their origin. Where does it sound like it's coming from? A worn serpentine belt tensioner allowing the belt to slip can cause a whistle or squeal noise... something to check.
Old 11-06-2007, 03:45 PM
I did pop the hood yet and check but it does sound like its coming from under there somewhere....im so stupid when i comes to cars. Could it possibily be a vacuum leak? A few people said the the whistling noice shouldnt really cause any problems its just more annoying than anything...would you agree?
Old 11-06-2007, 03:58 PM
old_master's Avatar
Advisor/Moderator
A vacuum leak could cause a whistle noise. If it is a vacuum leak causing the noise, it would be best to have it repaired as soon as possible. Vacuum leaks will cause a decrease in fuel mileage, and possibly damage the engine by injesting dirt. A vacuum leak will also cause the engine to run lean, which over time can damage the engine.
Old 11-06-2007, 04:11 PM
What all could it be? If it is the serp belt is that hard to replace?
Old 11-06-2007, 04:15 PM
old_master's Avatar
Advisor/Moderator
Depends what the problem is. Replacing the serp belt and/or tensioner involves removing the air inlet system, (air filter housing etc) and upper fan shroud, (7 bolts) for easy access to the tensioner.
Old 11-06-2007, 04:20 PM
Ok so hopefully its not something thats really expensive and easy to fix
Old 11-08-2007, 05:07 PM
Hmm thats weird...i havent been driving my van cause it was whistling and when i started it up today to let a friend hear the noise, it wasnt whistling anymore hmmm...but it did kinda sound like air was bein pushed out somewhere underneath the hood so maybe it is a vacuum leak somewhere
Old 11-20-2007, 01:04 PM
safblue98 safblue98 is offline
Had a similar noise after I had the Serpentine belt replaced. Figured it was inherent in the belt. Sound slowly disappeared over time, like 2 years as the belt wore in. Hope that helps.
Old 12-04-2007, 09:51 PM
mbmcgin1 mbmcgin1 is offline
sounds like your catalytic converter needs to be replaced if your hearing a rushing whistling sound, if so your losing gas milage and power, and if its a 99 and more than likely never been replaced, then you've got nothing to lose.
Old 12-04-2007, 09:53 PM
is that expensive?
Old 12-05-2007, 05:30 PM
rgmc rgmc is offline
4 to 5 hundred;
