Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 11-06-2007, 01:41 PM
brandon51780 brandon51780 is offline
HELP!!! 96 LHS no more start!
I have a 96 LHS 3.5l
Died at stopsign and will not start. Sounds weak on turnover.
Checked timing belt, looked fire no damage anywhere that i could see.
Checked fuelpump (makes noise on keyon). Changed fuel filter.
Checked for fire. ONLY 1 spark on 1 plug, none on another.
Any ideas? If you need more info tell me?!?!
Old 11-06-2007, 05:42 PM
Re: HELP!!! 96 LHS no more start!
Cam Position Sensor NOW NEW
Crank Shaft Sensor NOW NEW
Still doesnt start........ HELP!!!!!!!!!
Old 11-06-2007, 09:52 PM
Also a clicking noise in the left side of dash when i turn the key too on.
Old 11-07-2007, 07:13 PM
workaholic812 workaholic812 is offline
Your timing belt may look fine, how did you ckeck it? I had the same problem then i decided to take it apart, and found that the engine jumped time, so your going to have to take it apart
Old 11-07-2007, 08:59 PM
Thanks for the quick reply!
Too check the timing belt all i did was take the exposed bolts off and pulled the cover back some.
The belt did not look damaged, I have no clue how to check if it jumped time so explain if you think its necessary if you can.
I have a book i just need to know the easy way to know if it jumped.
AND im almost thinking its something in the dash, becauise of the weird noise i hear now when i turn the key on or off......
Old 11-26-2007, 06:02 PM
it was the timing belt btw.
