Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-06-2007, 12:00 PM
hahapopcorn hahapopcorn is offline
clutch -_-
All of a sudden my clutch pedal dropped to the floor and stayed there after i pressed it down and got really hard to put in/out of gear...but it re gains pressure once i bring it up and pump it a couple times (it will continue to lose pressure if i press it down slowly). I replaced the clutch master cylinder less than a month ago and the slave cylinder about a week ago. Also i tried bleeding the clutch, the shifting got better but the clutch still feels spongy and loses pressure when i press down on it slowly....anyone have any ideas on what this might be? Thanks.
1995 Talon TSi AWD
Current: 6-bolt, Big 16g Turbo, Blitz carbon face boost/air/fuel gauges, Act 2600, Evo VIII enkei rims, GReddy Type-RS BOV, K&N filter, DSMLink, Apex'i n1 exhaust w/ 3" down pipe, OBX short shifter, Turbo XS MBC
Soon To Come: 20g turbo, 750cc FIC, 255 lph Walbro, GReddy FMIC, AEM EBC
Old 11-06-2007, 12:13 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: clutch -_-
Did you check fluid level? Sounds like you still have air in it.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-06-2007, 12:38 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: clutch -_-
Same as what he said. Try bleeding the clutch again, I usually would bleed it several times before I considering it good enough to drive.
Also take a look to see if you can see any fluid leaks in the system. (which hopefully you won't considering you just replaced both cylinders)
1991 GSX 2.3 Stroker
Old 11-06-2007, 04:00 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: clutch -_-
Are you constantly loosing fluid? If so, you have a leaky hose. But bleed the system and see if that helps.
95 Talon TSI AWD
97 Eclipse GST
