Old 11-06-2007, 08:26 AM
fuct33 fuct33 is offline
help me
I have a 1994 4.3 v6 s10 can I run it with no oxygen sensor hooked up or am I looking at major problems
Old 11-06-2007, 08:49 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: help me
It will start and run without the 02 sensor.
But will not run right.
And will cause engine and cat damage if run over a period of time unplugged.
02 sensor is a main part on controlling fuel mixture.
What is your problem on 02 sensor or why are you wanting to run it unplugged?
MY
MT
Old 11-06-2007, 09:48 AM
Re: help me
I just put the motor in it and had the o2 wire routed around the crossover pipe (dont know why) and it got hot and started on fire now I dont know what wire is witch so I can splice new wires in ooh and there is no cat on vehicle
Old 11-06-2007, 10:27 AM
MT-2500's Avatar
AF - Advisor
Re: help me
No cat is not good.
It is illegal to run it on a federal highway without a cat.
I would suggest you get a cat on it.
If just wiring on 02 sensor burnt get another 02 sensor.
Splicing 02 sensor wires is not a good fix.
They will draw moisture if not sealed up real good and cause more problems.
MT
Old 11-06-2007, 02:23 PM
Re: help me
I dont understand that I know guys that have straight pipes or off road x pipes on mustangs or camaros I used to have a mustang with an x pipe and I had to buy a module on the o2 sensors because there wasnt any on it but ill try ro fix the one on the s10 I also have a parts truck so ill rob the cat off that
