Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 11-06-2007, 05:59 AM
Nivek1 Nivek1 is offline
99 montana NO HEAT
I am getting no heat ...99 Montana. t-stat changed ..cooling system flushed.getting up to proper temperture..but no heat in pass.compartment....do I have a malfunctioning accuator door??
Old 11-06-2007, 07:55 PM
jaso1108 jaso1108 is offline
Re: 99 montana NO HEAT
Does the air flow seem OK when you change the output knob? (For example, defrost, front vents, floor)? I had the actuator door right under the passenger side dash go bad on mine, but all it did was prevent it from redirecting the airflow per the knob indicator. I had all floor heat, all the time!
Old 11-07-2007, 06:49 PM
There is no heat at any setting, just cold air. Thermostat was changed and cooling system flushed and still no heat. Temperature runs between quarter and half.
Old 11-08-2007, 08:07 PM
F1200 F1200 is offline
I have the same problem! Changed thermostat and flushed cooling system and still NO HEAT in any position. Any idea what this could be causing this???
Old 11-15-2007, 09:21 AM
Smile Re: 99 montana NO HEAT
All fixed now - lots of heat!! Took to qualified rad shop and had heater core flushed separately... Had previously taken to cheap quick lube shop to have cooling system flushed but it turns out that their claim of being able to thoroughly flush a cooling system is completely false.
Old 11-22-2007, 10:44 AM
Old 11-25-2007, 07:47 PM
pvisser pvisser is offline
Send a message via MSN to pvisser
Had the exact same problem, turned out to be an air pocket in the heater core. Flush the core was the cure.
Then I noticed a intake gasket leak... Bummer
Old 01-20-2008, 08:46 PM
rockwood84 rockwood84 is offline
do not put a t-stat made in mexico as they will not open get one made in usa and it will open 180 or 190
