Old 11-06-2007, 05:20 AM
GPcarnut GPcarnut is offline
Sway Bar
Newbie here. I have a 2000 Grand Prix gt 3.8 my sway bar broke and was wondering if this was a common thing because i never saw one of these break before. And if some one came give me some steps in how to replace it would be great.
Old 11-06-2007, 08:18 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Sway Bar
Welcome to AF!!
Common problem on these cars. You can purchase a new one and they are not hard to replace you just have to jack up the front end, both sides, remove the tires then the old one and replace it with a new one. I suggest checking gmpartsdirect.com for a performance handling kit. Usually very cost effective and will improve your handling. One thing before you begin your replacement make sure you get a new set of end links as your old ones will probably break when you try to remove them.
Old 11-06-2007, 09:29 AM
Re: Sway Bar
thanks for the info.. Do i have to drop the a frame in the front to replace the bar or can i slide it out? I just bought the bar yesterday from the dealer 150.00
Old 11-06-2007, 11:12 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Sway Bar
check the tips and maintanance subforum. There is a detailed forum on how to replace it and i dont believe you have to drop the subforum.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-06-2007, 11:21 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Sway Bar
Good suggestion Tblake but I don't recall posting it yet. Just in case here is the link which has the procedure.
Click here
Timeslip 08/12/06
AF Community Guidelines
Old 11-06-2007, 12:47 PM
Re: Sway Bar
Thanks for the help much appreciated. I only asked about the frame being dropped in the front because the dealer said you cant put it on without dropping the front.
Old 11-07-2007, 12:03 PM
Pontiac Guy
Re: Sway Bar
The dealer is nuts. You may have to twist the bar around to get it in but it can be done. You don't have to drop anything other than disconnecting the end links and removing the sway bar mounts to get the old one out. Of course you need to remove the tires first! Follow Bob's instructional link and you won't have any problems.
Old 11-11-2007, 07:16 AM
Re: Sway Bar
Thanks for everyones help it was very helpful and the directions was right on. Ended up doing struts too and we went ahead and replaced the tie rod ends.Now time for an alignment check.
