Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-05-2007, 06:53 PM
mike561 mike561 is offline
Idle stop solenoid????
I discovered the green wire to the idle stop solenoid on the carb was disconnected from that little blue harness, i put it back in. whats that do and is it even neccesary?
2006 Chevy Cobalt LS
Old 11-05-2007, 10:01 PM
Blue Bowtie's Avatar
Registered Offender
Re: Idle stop solenoid????
The idle stop solenoid gets energized when the ignition is on and/or when the A/C compressor is on (it varied among several years and designs). The purpose is to allow the engine to maintain a reasonable idle RPM, yet to almost completely close the throttle when teh engine is turned off to prevent (or minimize) dieseling. Since the engines are tuned to run very lean and quite warm at idle, they would tend to diesel (run on) without some controls.
Old 11-05-2007, 10:03 PM
I remember it did that once but never again after that, and that was when i first got it too.
Old 11-09-2007, 09:47 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
When i first got my car it did the same exact thing. It hasnt happened since. Although, sometimes i turn the ignition of really fast or sometimes slow expecting it to diesel and it doesnt. Maybe sometimes the solinoid just gets stuck and doestn immediately close when you turn off the ignition, i'm just taking a guess at that.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 11-09-2007, 10:40 PM
Could be that, i remember it did it right as i ironicly pulled into the shop to have the timing adjusted which could have cause the dieseling too.
