Old 11-05-2007, 06:34 PM
Iron's Avatar
Iron Iron is offline
static noise from dash
Off the gas and at low speeds there is this annoying static sound coming from inside the dash. It dissapears when i give it gas and reach about 10 mph. I originally thought it was a problem with the multifunction because my brakelights/hazards didnt work properly, so i had that replaced. It fixed my brake/hazard problem, but the weird static noise is still there. It isn't loud enough to be a bother with some music on, but it still bugs me and I'd like to know what it is, any ideas?
95' Z28, 00' GTP
Old 11-06-2007, 03:27 PM
old_master's Avatar
Advisor/Moderator
Re: static noise from dash
Do the HVAC controls work properly? ie are you able to switch air flow from defrost to heat etc?
Old 11-06-2007, 11:05 PM
burnchassis3 burnchassis3 is offline
I also get a static type noise (not radio) from dash area..and I can not switch the defrost to heat..it always comes from the vents unless I close them,then It works.
Whats that mean?
CS
Old 11-07-2007, 11:25 AM
old_master's Avatar
Advisor/Moderator
More than likely there is a vacuum leak in the HVAC system, and that's what you're hearing. Could be a vacuum line, an actuator, or the control switch.
