| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
PLEASE HELP! 1997 eclipse no spark after engine swap
Hello,
We have a 1997 Eclipse AWD, turbo, AUTO!, that had an engine knock. We got a used engine from a wrecking yard (from a 5 speed) and installed it. Everything hooked up fine except we had to switch the intake manifolds. Now the car has no spark! No codes are shown in the computer. Possible that crank sensor is different and not showing up on computer hook up? Needs different PCM? Any information would be greatly appreciated!!! Thanks! |
Re: PLEASE HELP! 1997 eclipse no spark after engine swap
What year was the car that the motor came from? If it was from a 90-94, you'll need to switch around a few sensors and swap some spark plug wires.
Also why did you have to switch intake manifolds?
1991 GSX 2.3 Stroker |
By the way, the engine is out of a 1998.
you shouldnt of had to switch anything around.... 97-99 are the same.. as for spark.. check for the cas being 180 out.. crank sensor..
Its a Dsm thing... <img src="http://www.dsmtuners.com/gallery/data/500/44010Pcdv0154-thumb.jpg"> |
Are you sure it does not matter if it came from a 5 speed or an automatic?
Thanks! |
Motors are the same between auto and manual.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
