Old 11-05-2007, 09:02 AM
cody84 cody84 is offline
heating problems with my 92 taurus 3.8
as said in the title i have a 92 taurus with a 3.8 and ive been having heating problems...i start my car up for work every morning and after running for 15 minutes i get in the car and it is blowing cold air..but after awhile when im driving it starts to blow warm air..it seems the faster i go the warmer the air and the temp gauge usually sticks at just above normal and doesnt move..what could the problem be...could i need a flush or should i change the thermostat...let me know what u think thanks
Old 11-05-2007, 10:21 AM
Millermagic Millermagic is offline
Re: heating problems with my 92 taurus 3.8
It could be a bad heater core or a bad thermostat. I had a similar problem in my 01 taurus, the thermostat was stuck shut and I had no heat.
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
Old 11-05-2007, 12:42 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
In addition to the thermostat, you could also have issues with the water pump. Water pumps have been a weak point on many of the Taurii. Use the "Search this forum" feature from the Taurus forum main page to search for the keyword "impeller."
-Rod
Old 11-05-2007, 07:21 PM
the temp level in my car never gets to the hot position it is way more towards the cold so could it still be the water pump then, because i do get heat every once in awhile and when i do its really hot
Old 11-05-2007, 07:22 PM
i wanna try figure it out before i stick money into a thermostat or a radiator flush and have that not be the problem
Old 11-05-2007, 08:16 PM
shorod's Avatar
SHO No Mo
You could also try backflushing the heater core or checking for air pockets.
There have been A LOT of posts on this forum for heating issues, and a lot of cognizant folks have posted their findings. Use the search function and search for "heat" and related key words. I think you'll find several posts with symptoms similar to what you describe.
-Rod
