Old 11-05-2007, 04:22 AM
jefgentry jefgentry is offline
need to know if my subs can handle my amp
i have a 1200 watt diamond amp and 2 12-inch alpine type-E 1241 subs. Will my amp blow these subs?
Old 11-05-2007, 05:53 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: need to know if my subs can handle my amp
that mostly depends on the music you listen to
Old 11-06-2007, 04:56 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
has alot to do if you set your gains correctly to.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 11-06-2007, 06:19 PM
NotoriouslyLoud NotoriouslyLoud is offline
^i agree with both above post. Music will play a large part as well as your gains being set up correctly. Something else that effects power handling is the box.
Big D
founder of
Team Notoriously Loud Mafia
1 fi audio 18 btl fully loaded
1 soundstream xxx-6500
1 AVH-P5700DVD
2 G34 Yellow top
250 amp HO alt
bassrace 139.9 all day baby
Old 11-07-2007, 12:39 AM
i listen to rap and i usually turn the gain up three quarters of the way
Old 11-07-2007, 01:55 PM
new2mitsu new2mitsu is offline
are you running in a series or parallel?
Type E's are 4 ohm SVC right? and your amp is 2 ohm stable, i believe, type E's are an RMS wattage of 250, and a max of 750... so it would be fine at about half gain, or a lil more... plus i know nothing about Diamond Amps
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 11-07-2007, 05:48 PM
pre98zetec's Avatar
you don't know if its fine at half gain or not, it could be clipping the signal and ultimatly blow the subs.
power usually doesnt kill the subs (it does, but to a point).. clipping the signal is the # 1 reason why people blow speakers.
-Josh-
Old 11-09-2007, 08:05 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
How you going to tell him how to set his gain on his amp? You don't even know what head unit he has. The voltage on the outputs from the cd player has a HUGE impact on the gain of the amp.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 11-09-2007, 08:34 PM
pre98zetec's Avatar
preamp voltage doesnt mean much if your setting the gains with a DMM
-Josh-
Old 11-09-2007, 09:22 PM
Audio Guy
False .... POWER kills speakers, clipping in and of itself, does not harm speakers.
Old 11-09-2007, 09:54 PM
pre98zetec's Avatar
which is why i said to a point, of course your going to blow a sub on 1000rms if its rated for 350.. if you have nice clean power you can easily run 500rms on it daily with no harm.
i dont see how you say clipping doesnt kill subs, if it doesnt why can you burn a coil on a 2000rms sub with 400w?
-Josh-
Old 11-09-2007, 11:03 PM
Whats a DMM?
Caleb
vanilla gorilla
Old 11-10-2007, 09:09 AM
pre98zetec's Avatar
digital multimeter
-Josh-
Old 11-10-2007, 03:15 PM
Audio Guy
you can easily double (and possibly triple) the average power output of an amplifier if you clip it hard enough. The clipping itself is not causing the damage, it's the extra power - and the way it's tranmitted to the speaker. There will no longer be peaks, just a lot of "area under the curve", the poor speaker never gets a break and finaly fails from thermal stress.
