Old 11-05-2007, 01:17 AM
d1nonlyjv43's Avatar
d1nonlyjv43 d1nonlyjv43 is offline
Brakes
96' Chevy Cavalier 2.2l
Problem:
When coming to a completer stop the brakes start to lock up in the back it seems like and the back of the car sluches downwards. When pedal releas from complete stop back end raises up a little.
Is my ABS kicking in and causing my rear brakes to lock up in the back and is my suspension gone or what/ Please help was planning on doing GR2 struts with skunk 2 Lowering springs on my suspension drop soon. Also have 17 inch wheels on car now is this goign to be a problem with the ride?
Old 11-05-2007, 03:25 PM
red99ws6 red99ws6 is offline
Re: Brakes
mine is doing the same thing. let me know if you come up with anything
Old 11-05-2007, 04:47 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: Brakes
does it make a "popping" noise at all when you let off the brake?
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 11-05-2007, 05:46 PM
shakewell shakewell is offline
Re: Brakes
Make sure the shoes don't need to be replaced first. If they look ok, you probably need to adjust them. Lift up rear wheels and rotate adjusting wheel inside drum until the you can spin the wheel but it has resistance and stops on its own.
An under-adjusted drum brake can cause the shoe to pitch out when you apply the brakes and the shoes grab the rust ridge on the drum causing it to lock up.
Old 11-06-2007, 03:08 AM
muff34 muff34 is offline
Re: Brakes
Ditto Shakewell and it would not hurt to use some brake cleaner to clean things up in there as well
Life Is A Highway ,Enjoy The Ride
Old 11-07-2007, 03:04 PM
Re: Brakes
Iv'e done that already had them re adjusted and sanded with emery cloth and cleaned with brake clean and drums resurfaced worked for about two weeks but came back now what?
Old 11-07-2007, 07:54 PM
Re: Brakes
adjust them again.
When you're adjusting 'em you should bang on the drum and rotate the drum and check it again. A lot of times they're not completely adjusted up the first time (unless you really know what you're doing) so after driving a while they may need to be adjusted again. I know it's a PITA but you should get it right before bad weather hits.
Dunno if that's really your problem or not but it sure sounds like it to me.
