Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-04-2007, 09:52 PM
SterlingGsilver SterlingGsilver is offline
my new car is jacked up
i just baught a 95 eclipse non turbo automatic. The transmission is acting funny. While driving the transmission will stay in a gear and stay at high rpms for a while before shifting into the next. Then when I stop the car acts like it still wants to go (stays at 1800 or so rpms instead of 800 where it is supposed to idle. Whats going on?
Old 11-04-2007, 09:58 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Re: my new car is jacked up
Doesn't make it the trans guy , could be a fuel / emission issue. My TPS went out a while back and the RPMS were up around 1400 in nuetral :/ do you have a CEL light on ? is there smoke or liquids coming the the exhaust pipe ?
The only way a auto will stay in gear at high rpms is if it's continually being feed power up around the 5500 - 6000 rpm range then force shift into the next gear. How many miles on the car ? does it look abused ? do a carfax and see the service records.
2004 Mazda 6i
1997 Tahoe
Old 11-04-2007, 10:56 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
The transmission not shifting is a different problem than your high idle in gear I think. When was the last time you changed the tranny oil and filter? That should help with the odd shifting. Do you have any CEL's like Mazda said?
95 Talon TSI AWD
97 Eclipse GST
