Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-04-2007, 08:29 PM
Andykid456 Andykid456 is offline
More probablem please help
Hey guys thanks for your time i have two probablems i recirculated my Bov And my car is still running rich. along with the engine check light being on it comes up as mdps and isc sensors. could that cause it to run rich. another probablem is every time i shift to 3rd gear it grinds a little. i would like to kknow how to ajust my cluch and do you think that there can be air in the line the guy i brought the car off of said its an act 2600 cluthch but it feels like a 2100 everyone says to me please help thanks
Old 11-04-2007, 10:06 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: More probablem please help
What in the world sensors are those? The only thing you can adjust is the clutch pedal from inside the car, but you can also try bleeding the clutch too. If bleeding doesn't help, try changing the fluid to Pennzoil Synchromesh or BG Synchroshift.
95 Talon TSI AWD
97 Eclipse GST
Old 11-05-2007, 07:25 AM
The sensors are thae manifold defferential pressure sensor. amd idil sensor control can that make the car eun rich as hell? and i cant ajust where the clutch catches only the hight of the pedal. anotherthing where is the nipple to bleed the cluth i realy dont think theres anything wrong with the tranny because is was doe like 4 thousand miles ago thanks.
Old 11-05-2007, 04:34 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
When you rehooked the BOV up recirculated, did you reset the computer? Do this by unhooking your battery for about 10 seconds. That should clear out any codes in there. If you fire it up and the codes come up, well it's something else.
Also if you are griding in 3k. Take a look at the clutch cable and where it connects to the tranny. Make sure those cables or the shifter levers aren't rubbing on anything. IF that's all good, it sounds like the tranny itself.
1991 GSX 2.3 Stroker
