Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 11-04-2007, 07:00 PM
amodea1 amodea1 is offline
2002 SVT?yes/no
hi everyone, i am looking into getting a focus and i figured i might as well go all out and go for the SVT.
i have found a 2002 with 80k miles and in great shape mechanically with a ram air intake, and pretty much stock other than that. the cd changer is jammed though. the guy is asking $7000 for it. he said the tires will need to be replaced soon too. any advice?
Old 11-06-2007, 12:26 PM
Cadillakin'98's Avatar
Cadillakin'98 Cadillakin'98 is offline
Re: 2002 SVT?yes/no
that sound about right....try and get a lil bit lower if you can....
if it had 80K, the Clutch TSB must have been done by now. check the clutch pedal for vibrations when operating. The 6-disk CD player had a lot of problems apparently. I never had a problem with mine. You can find the stock units on ebay.
Old 11-15-2007, 09:44 PM
wfsdno wfsdno is offline
Re: 2002 SVT?yes/no
Fun little car! I had the 03 SVT (zx5) and it was a blast. I also had the clutch problem and fought with Ford over it. Finally got the clutch replaced (this before the TSB). Sold it and now I really miss it!!
Go for it, but either knock off $500 or have him put on new tires.
Good Luck!!
Old 11-20-2007, 08:41 AM
65Ponchoboy 65Ponchoboy is offline
Send a message via AIM to 65Ponchoboy
Re: 2002 SVT?yes/no
that sounds like a weak deal... you can find one for a little bit more with less mileage. just do some research. I bought mine at a dealer, had 56k miles on it, paid 10k and it came with new tires, brakes, and all the options except for the EAP
www.stangclub.net
www.ueperformance.com
BOMC member
Old 01-10-2008, 07:09 PM
elhefe4 elhefe4 is offline
Re: 2002 SVT?yes/no
The stock cd changers don't work well at all. Ford says not to play burned cds cause they are thicker and get jammed. I think they said around 400 dollars for a new replacement. Better off going with an after market unit. Also, you can get a svt suspension kit for around 250$. Good way to save money is to go with a plain old zx3 and upgraded. Good luck.
