Old 12-02-2002, 11:39 AM
_835_'s Avatar
_835_ _835_ is offline
Send a message via ICQ to _835_ Send a message via Yahoo to _835_
Brake Disc color ?
Hi guys,
just one question, what paint color do you use for painting Brake Disc ?
_835_ from ASPHALT models
IN PROGRESS / WAITING Too much to list all And so many project in my head....
Old 12-02-2002, 11:42 AM
freakray freakray is offline
AF Modelrater
usually they end up being steel or gunmetal, but now I have some Alclad I will be experimenting with some different colors to see which gives the most realistic effect.....
Ray
AF User Guidelines
Old 12-02-2002, 11:43 AM
Vric's Avatar
Vric Vric is offline
Tamiya XF-56 and Testor Silver (for the disk)
and for the pad it depend.. Gold, Red, Yellow or XF-56
Old 12-02-2002, 11:57 AM
giordano giordano is offline
jus regular foil will do, then sand it lightly with a flat file or sand paper to make that used look.
Old 12-02-2002, 12:16 PM
Veyron's Avatar
Veyron Veyron is offline
Smile
Air brush on some Gunze Iron metalizer, then rub it with a Q-tip.
Old 12-02-2002, 12:52 PM
Midnight Racer's Avatar
I just use Testors silver.
Old 12-02-2002, 03:26 PM
rcmaxx rcmaxx is offline
Tamiya Flat Aluminium, then 50/50 black/thinner brushed over aluminium then removed before it dries(trust me, it does something, but I can't explain it) then sanded to make the used look.
Old 12-02-2002, 04:58 PM
RallyRaider's Avatar
Zomby Woof
Depends on the car, consult your references
One technique I like to use for vented disks is to first spray the whole assembly gunmetal then drybrush silver over the top. Applying the drybrush in a circular motion, mimicking the abrasion of the pad on the disc. This leaves the vents the darker gunmetal and gives the raised surface a shiny 'worked' look. After that, I hand paint the hub and caliper details. Done
Old 12-02-2002, 05:56 PM
daggerlee's Avatar
Thumbs up
Sounds like a top technique. I've got to give it a try sometime.
Dan
Old 12-03-2002, 12:37 AM
_835_'s Avatar
thanks to all for the help, i take all tips as note, and i will try them to find the better way.
MAny Thanks
Old 12-03-2002, 01:38 AM
primera man's Avatar
"P-Man"
Tamiya X32 is what i have found to be the best so far
View All My Models Here.
Old 12-04-2002, 04:56 AM
hermanchauw hermanchauw is offline
For simulating carbon disc brakes, is it better to use gloss, semigloss or flat black? Or any other colour?
Beginner in car modelling
Currently working on:
Academy 1:35 Hummer, semi-scratchbuilt rollcage, scratchbuilt seat(s), scratchbuilt dashboard, Civic Sir2 wheels (22inch), smoothened body, radiator exhaust vent...
Old 12-04-2002, 05:11 AM
Zomby Woof
Carbon discs are usually a matt grey in colour. But it varies from car to car, from year to year. Best find some reference photos of the car you're building.
Did you have any particular car in mind?
Old 12-04-2002, 05:20 AM
Just customising a model car, not making a replica of any particular car.
Old 12-04-2002, 05:35 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
It depends on the car. If the brake discs aren't easily visible, I would just paint them with silver paint. If they are, I paint them with Silver pain then polish them.
If it is meant to be a old, used looking car, I don't polish them. It all depends on the model really. I am thinking of trying a chroming compound soon...
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
