Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 11-04-2007, 03:59 PM
cageincali cageincali is offline
After Market Radio Install
I want to install a sony radio into my 1989 325i. I've installed this radio into several other cars, but the wiring on the BMW is a bit wierd. I've got a wiring schematic, but the colors on the paper don't always match the colors on the wire. Also I'm not sure which wire to use as the power source or if I should ground the radio to the chasis or to the ground wire from the dash..... anyone out there have any experience with this that they could give me some tips on? Thanks.
Old 11-30-2007, 12:42 PM
ricedarian ricedarian is offline
Re: After Market Radio Install
im looking into getting new brakes. so I am in the market to purchasing new brake pads....I have only come across a couple BMW sites that have those available...have you heard of http://www.myhotbmw.com/bmw_parts/Brakes tell me what you think or if you have suggestions?
Old 02-08-2008, 07:38 PM
qleooo qleooo is offline
it ahs to be hard wired theres no way around it it had to do it to my buddies 88 fairly simple though but for your brake pads try bavauto.com
Old 07-10-2008, 11:44 AM
Broken-wrench Broken-wrench is offline
Check with Crutchfield. They have a harness that will allow you to remove the plug from the back of the radio and will allow you to take the radio pigtail & splice it into the aftermarket harness that will then plug into your cars wiring! Just did this on my '94 E36.
As for brakes, get some Cool Carbon pads from Bavarian Autosports. NO DUST OR SQUEEL!! You'l be checking your mirrors in a panic stop to see if anyone is going to hit YOU with these pads! I put them on with their gas slotted rotors and what a differance!
