Go Back   Automotive Forums Car Chat > Classic Cars
Classic Cars Do you just love the classics?
Old 11-04-2007, 03:02 PM
chevelle53144 chevelle53144 is offline
Chevelle electronic ignition question
I have a 1967 Chevelle SS with electronic ignition. The motor was worked on and now the car will start but, will not shut off. You have to pull the coil wire to get it to stop. Any idea what caused this and what I can do to fix it?
Someone said something about a yellow wire that should not be connected.
Old 11-05-2007, 08:01 AM
maxwedge maxwedge is offline
A990 racer
Re: Chevelle electronic ignition question
What electronic ign.? OE was not electronic. #2 check how it was wired, should be wired to the ign switch somehow to operate only in start and run, pretty basic.
Old 12-05-2007, 08:50 AM
SpinnerCee's Avatar
SpinnerCee SpinnerCee is offline
The 12v power to an HEI type ignition should be wired as mentioned above -- many times it is connected at the fuse block to a terminal that is always "hot" -- this will prevent the ignition from shutting down the engine when the key is turned off and drain the battery. The terminal used should be hot in RUN and START.
There is also an ACC terminal on the fuseblock that is only hot in run -- this will cause a strange no start condition where the engine will crank in the START postion but only try to (and possibly) start when the key is released.
.:: DigitalMIX by djSpinnerCee ::.
Old 02-01-2008, 05:29 AM
72chevelleOhio 72chevelleOhio is offline
if the charging system was converted as well it could have been mistakenly wired in to the ignition side keeping it "hot" when the key is turned off. this also burns up modules in hei systems, not that I ever done it or anything.
Old 02-01-2008, 09:21 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
PTC_Admin- Please read the Community Guidelines (to which you agreed to follow when you signed up at this site.) In it , it forbids advertising other forums.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
