Oil Pressure, whats correct 99Silver-6.0
I have 99 Silverado, 6.0Ltr, 2 Whl Drv, running castrol gtx 5-30, fram oil filter with antidrain back valve.
At 600Rpm, oil pressure 50, At 2000Rpm oil pressure 75+. At times pressure seems to almost pulse between 60-70. Is this normal? Is Fram Oil Filter with Anti Drain valve, causing abnormal high pressure? Changed oil and it was clean. |
Re: Oil Pressure, whats correct 99Silver-6.0
What was it before, what is different?
I use Baldwin filters, Fram to me in the past has done similar problems and I live in Arctic conditions and I have seen Frams blow apart.
2002 Silverado 3500 extended cab 4x4 dually 8.1 (496cid) Vortec, Allison 5spd w/OD All front lights, fog lamps converted to 5000K HID, all running lights chip LED Modded from LED sign double row red LED sequential T/S, running and brake lights mounted below tailgate. New side and rear modded emblems for visual effects. Escalade instrument cluster and auto dim LED outside mirrors. Front and rear concealed amber Tomar strobe system Modified for Alaska extremes |
