Go Back   Automotive Forums Car Chat > BMW > 8 Series
Old 12-02-2002, 11:17 AM
Lester Turner Lester Turner is offline
840 computer display flakey
My 1995 840 has had the in-dash computer/display replaced 2 times because the display became intermittent (numerous vertical lines do not illuminate).
The first two times were under warranty. Now, the display is flakey again, and the car is out of warranty.
The dealership solution is to replace the unit. Is there a source for aftermarket repairs to this unit?
Anyone have any luck with do it yourself repairs to the display?
Thanks,
-t
Old 01-17-2003, 12:28 AM
Copper Copper is offline
Is it the pixels themselves on the OBC out or is it the whole display?
Sean
2002 Toyota DBL-Cab Pre-Runner V6
1991 BMW 850i
1999 Ford Crown Victoria P71 Interceptor
Old 01-17-2003, 03:10 PM
Just odd pix, not the whole display, and not all the time.
Sometimes, all the pix are ok, and at other times some will not light. I suspect temperature is a factor.
I also suspect that there is either a header connector or ribbon cable connector that is the culprit, but I have not yet tried to figure out how to get the OBC out of the dash so that I can have a look inside.
Is this OBC common to any other models?
All help appreciated. Thanks,
-t
Old 06-05-2003, 09:48 PM
etype2 etype2 is offline
Yes. I have the same problem with my 93 850Ci
The message is partially readable.
I think our best bet is to buy new unit. I mean used.
Old 06-08-2003, 11:17 PM
hakka's Avatar
hakka hakka is offline
If you do get a new MID, write to BMW NA and ask for a refund, they will probably reimburse you. They did this for me and several other guys I know.
