Old 11-04-2007, 01:58 PM
Ryder1964 Ryder1964 is offline
Engine bogs down when I get on
I have a 94 truck 5.7 motor. When I step down hard on the gas it acts like it floods out and bogs down. Idles fine. I changed cap, rotor, plugs and wires. Gets gas through both injectors. Replace the catalytic converter. Im at my wits end.
Old 11-04-2007, 02:57 PM
maxwedge maxwedge is offline
A990 racer
Re: Engine bogs down when I get on
How about checking fuel pressure?
Old 11-04-2007, 03:00 PM
its getting fuel. I can look in the bowl and see the fuel spraying.
Old 11-04-2007, 03:07 PM
A990 racer
Ok, but if the pressure is low under power it will bog down, also try dropping the exh., to check the cat. 10-13 psi FP, how about a clogged fuel filter?
Old 11-04-2007, 03:19 PM
Havent tried filter, wouldnt it be sluggish all the time if that was it? Also remove cat and tried it without. I dont have FP gauge.
Old 11-05-2007, 12:09 AM
Browning151's Avatar
Browning151 Browning151 is offline
I would def. replace the fuel filter, I had a 92 w/the 4.3 that did the same thing, replaced plugs and wires, got a little better then replaced the fuel filter and it had ALOT more power and didnt bog down anymore
99 Z71 Ext. Cab OBS, Indigo Blue w/Gray Leather....
