Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 11-04-2007, 11:01 AM
stregisfalls stregisfalls is offline
Send a message via Yahoo to stregisfalls
3.4 liter engine
new problem: on the lower intake manifold are numbers cast into the manifold. the back ones are stamped 2-4-6, the front ones are 1-3-5. The plug wires are marked gm originals however they go to the wrong cylinders. the longest wire marked 6 goes to 5, 4 goes to 3 and 2 goes to 1. on the other hand the shorter ones go to the rear set. the chilton's manual doesn't coincide with what I have, backwards just like the haynes book. what gives and what shall I believe. I don't want this thing blowing up!
Old 11-04-2007, 02:51 PM
maxwedge maxwedge is online now
A990 racer
Re: 3.4 liter engine
Wow, this job has really tortured you, check this link. http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old 11-04-2007, 03:24 PM
I looked at the autozone page. so am I to believe to ignore those cast numbers and go with the firing order and spark plug wire placement as pictured on their website?
Old 11-05-2007, 08:18 AM
A990 racer
Yes. What can you loose at this point.
Old 11-05-2007, 08:24 AM
I called the olds/chevy dealership this morning at 8 am. They said to go with what's stamped on the manifold, therefore 2-4-6 is near the coil pack and 1-3-5 is near the radiator. so everything I read in chilton's and autozone is backwards. Even the arrangement of the coil packs is different in the autozone diagram.
