Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 11-03-2007, 07:03 PM
missamerica missamerica is offline
2001 saturn sl1 will not start when hot
ok well my car will start when its cold but if i drive somewhere shut it off and run in quick come back out the car will not start i have to wait for it to cool off. its not the battery cause radio is fine lights come on, car just wont start and there is no click or nothing when i turn the key. its a manual trans. thats not all 9 codes came up when checked with the computer. just wondering what is going on with my car.
Old 11-04-2007, 09:40 PM
Cat Fuzz Cat Fuzz is offline
Re: 2001 saturn sl1 will not start when hot
Give the codes.
Old 11-04-2007, 10:37 PM
not sure what all the codes are but i know 2 of them one is oxygen sensor and one is fuel intake sensor. think that there might only be a couple of bad sensors and the rest are just tripping off of the couple that are.
Old 11-05-2007, 11:14 AM
jaimeleah jaimeleah is offline
This is happening to my '98 SL1 too...it will start if I press the gas pedal down, but otherwise will stall if the engine is hot. Suggestions?
Old 11-05-2007, 04:32 PM
yaz4real yaz4real is offline
jaimeleah... should start your own post since your symptoms are not the same... as a start... look into a engine coolant temperature sensor for your car.. ECTS.. $10 - $15 depending where you get it.. how does your in car temperature gauge work by the way..
To Miss America.. post the numbers to the two codes leading to nine codes your computer gave up instead of what someone told you what they were for... usually a Saturn not wanting to start when hot is a crank position sensor going bad... however the codes will help
Old 11-05-2007, 06:25 PM
found out what the problem might be...the cylinoid on the starter is sticking had somebody lift the car up and they took a rod and tapped a hammer at the end of it when the car was in the run position and it started up...havent had it not wanting to start after that....thank you for the replys
Old 11-05-2007, 06:36 PM
Originally Posted by missamerica
car just wont start and there is no click or nothing when i turn the key just wondering what is going on with my car.
This part of your original post went right over the top of my head... that points to the starter a majority of the time.. good to hear its fixed for now..
