Old 11-03-2007, 04:45 PM
GirlBear's Avatar
GirlBear GirlBear is offline
Talking Not 1 Drip/Drop
As some of you know Ive had a huge issue with leaking fluids. Well It was the Oil and Tranny cooler lines. And Ive replaced'em all. No more leaking. it was sooo bad that the fluids ran down on to the exhaust and blew all over the entire underneath and in the engine compartment. From hitting the cross pipe from the driver side manifold to the Passenger My blazer would smoke real real bad like a James Bond smoke screen. It was basically undrivable. Caught on fire once also. But I am so excited shes solid again Until the next hurdle any way. We cut a hole in the passenger side floor to get to the Tranny lines. welded an old Texaco sign in its place. lol.
http://jowulf.deviantart.com/
Old 11-04-2007, 06:31 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Not 1 Drip/Drop
That's mighty fine, good work.
Old 11-04-2007, 07:36 AM
DINO55's Avatar
DINO55 DINO55 is offline
Re: Not 1 Drip/Drop
BRAVO, I knew you could do it GirlBear.......................
Dino...
1998 BLAZER LS Vin-W 4Dr 2wd
2004 Cavalier LS 4Dr 2.2 Ecotec
"Good Part's ain't Cheap--Cheap Parts ain't Good"
Old 11-04-2007, 08:13 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Not 1 Drip/Drop
GirlBear
Good for you Kid.
You can put a feather in your hat now.
You checked it out and found the real problem and got it fixed.
Good Work.
Good Luck with it.
MT
MT
