Old 11-03-2007, 01:22 PM
slimshitty slimshitty is offline
Unhappy 96 2.4L manual transmission problem
Yesterday I was driving and lost 2nd gear and reverse. I checked the shift cables, as I had to replace one about six months ago. Neither of the cables appear to be broke as they are moving the plunger on the tranny. Are there any adjustments for the shift cables?. I've searched the forums but only find info referring to broken cables but I'm sure that neither of the cables are broken. I had a friend shift through the gears while I watched the tranny and both cables are moving in both directions. Does anyone know an adjustment procedure that will return 2nd and reverse for me ?
Old 11-03-2007, 09:11 PM
Re: 96 2.4L manual transmission problem
I've read a little more and have another question as well. It seems, from what I've read, that someone has suggested adding Synchromax fluid to remedy a problem similar to this. Can anyone confirm that low fluid in a manual tranny could cause my particular problem?
Old 11-03-2007, 11:50 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
i know if its low on gear oil (not tranny fluid) it will cause shifting problems, however i dont know if it would cause the problem your describing
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 11-04-2007, 02:36 PM
Ok ... to update: checked the transmission fluid level ( and it is tranny fluid not gear oil; GM Synchromesh transmission fluid ) and, although it was slightly above the add mark, it's not critically low to a point to cause shifting problems. However, after taking the car on a short test drive I now am missing 2nd, 4th, and Reverse. Basically all of the gears on the bottom of the pattern. I checked a Haynes manual for this vehicle and find no mention of shift cable adjustment. There has got to be a Cavy gearhead out there who has encountered this before. Does any one know which cable affects 2nd, 4th, and Reverse?
