Old 11-03-2007, 10:51 AM
notechie notechie is offline
98 safari power steering pump replacement
can you replace a speed dependant power steering pump with a regular power steering pump
Old 11-03-2007, 04:51 PM
old_master's Avatar
Advisor/Moderator
Re: 98 safari power steering pump replacement
Yes, they are interchangable however, the EVO (Electronic Variable Orifice) feature will not operate. You'll have to do some "creative plumbing" due to the difference in fittings though. You can also swap the EVO fitting from the old pump to the new pump.
The EVO system reduces power assist as vehicle speed increases to give the driver a better "feel" for the road. If you use a standard pump, as vehicle speed increases, the steering will feel "sloppy", (not nearly as responsive).
