"Level My Ride"
I would like to lift the front of my '91
2 or 3 inches, so that it doesn't look like it's doing a nose dive. What is the easiest solution? Rod |
Re: "Level My Ride"
The easiest way is to use spring spacers.you should get 2inches.make sure that the shocks are good.the proper way would be to install new springs that are stronger than oem . these vehicles have weak springs . I also used air shocks in the rear and adjusted for slightly higher rear. another problem area is the front stabilizer bar hardware link bushings. too much movement here will damage springs as well as shocks that are weak. In the end, adjust height so that drive shaft is straight as possible . this will prevent damage to the cv joints. If you do these easy cheap fixes the handling will improve greatly and you'll probably get those new stronger front springs..
Re: "Level My Ride"
I have Monroe air shocks on the back of mine also.
Even with them at about 50lbs. it's high in the rear. I don't mind that. I just like the look of a higher front also. What is a good after-market source for new front springs? I think I can machine some simple 2" spacer blocks for the front stabilizer bar after installing new springs. Thanks for the help. Rod |
Re: "Level My Ride"
I thought about rear air shocks for when my back seat is loaded, the stance of the car still looks normal. Did it change the feel of the ride too much where it felt like driving a pick up?
Re: "Level My Ride"
In my opinion, the air shocks on the back of my old Grand Am certainly did make it feel like I was driving a truck, plus they were ineffective as high-performance shocks. The car tended to fishtail and experience wheel-hop under acceleration.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Re: "Level My Ride"
If some of the problems with ride height are due to the 17 year old springs being weak and sagging, installing good springs will help. Raising the ride height 2-3" beyond what the original height was supposed to be can introduce problems.
Raising the front 2-3" will require a significant camber adjustment, and even with removal of all the upper control arm shims, there might not be enough space to get it set properly. This will also affect caster if there is insufficient adjustment, and may affect bump-steer once the other handling angles get close to their limits (the tie rod angles are going to be markedly different than the design intended). If you don't mind chewing off your new front tires every 10,000 miles, and don't care about being able to steer, it won't matter. The appropriate method would be to install offset spindles.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
Re: "Level My Ride"
Silicon212, you said the car would tend to fishtail in which I can see, but would the tires break lose easier when mashing that pedal to the floor from take off because of the unsprung weight?
Re: "Level My Ride"
sorry
1997 Jeep Grand Cherokee Laredo 4.0L 2004 Jeep Grand Cherokee Laredo 4.0L 1983 Caprice Classic 5.0L |
Re: "Level My Ride"
sorry
Re: "Level My Ride"
It had 2.56 gears in the 7.5" diff/axle. I don't know what you mean by bringing up unsprung weight - it was lighter on the Grand Am than the Caprice but the Caprice will light'em up and the Grand Am couldn't on dry pavement. Inasmuch as the handling, the air shocks were almost like not even having shocks in that the car would bounce over the road profile rather than follow it. Unlike bad shocks, they would tend to lock the springs, taking out some (well, a lot) of rate. That's what caused the car to bounce and not follow the road. It got real floaty on rough roads. Oh, and the Grand Am was actually heavier than my Caprice - by almost 600 pounds!
Re: "Level My Ride"
They almost sound unsafe....not really what I'm after. Unsprung may have been a bad choice of words, just sounded good at the time. It seems when you hammer the gas the ass end drops almost forcing weight on the rear wheels where as with the lift the back doesn't drop as much or not as all. If that makes sense...it's not making much to me either now that I'm rereading this...
Re: "Level My Ride"
Re: "Level My Ride"
what i wrote was, the stiffer the rear suspension the less the rear will squat under acceleration, so yes the tires will spin easier. sorry for the confusion
Re: "Level My Ride"
If I were to just try a new pair of springs,
did any of the other cars of that series (Roadmaster,Olds 98, wagons) have a heavier rated spring? Where do I shop for these springs? |
Re: "Level My Ride"
