Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-02-2007, 10:42 PM
DSMNerd6889 DSMNerd6889 is offline
No Spark?
Hey guys, my buddy and I just put his 90 GSX back together and we've run into a small problem. We can't get it to start. The motor turns over, it just won't fire. I'm not sure, but I think there is no spark. The reason why I say I'm not sure is because we just took a spark plug wire off while trying to start it and didn't see any spark. I'm not sure if that's the way to test for spark. We tried swapping out ignition coils, and don't really have any other ideas. Anyone got any thoughts? Thanks in advance!
1990 GSX
PTE SC6152e, tubular manifold, FIC 650's, wiseco/eagle internals, dsmlink, TRE tranny, Apexi dp and cat-back, Apexi EGT and Boost Gauges and Turbo Timer, Megan Racing FPR, Walboro 255 Pump and much more to come.
Old 11-02-2007, 11:04 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: No Spark?
Ignition transistor gone bad maybe?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 11-02-2007, 11:35 PM
Re: No Spark?
Sorry to be such a newb, but where would that be?
1990 GSX
Old 11-03-2007, 10:33 AM
Re: No Spark?
This little guy here... I can't remember where they mount them on a 1g at... Either on the intake manifold or on the firewall...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 11-03-2007, 11:50 AM
Re: No Spark?
Okay, I tried swapping that out with two others and still nothing. I'm wondering if it could be the fuses that are one the passenger side of the engine bay, but I can find my fricken voltmeter...
1990 GSX
Old 11-03-2007, 12:05 PM
Re: No Spark?
Hmmm... I would definitely be checking fuses out next then... Hopefully you'll find the problem there. If not, then you may have to move back one more step to the ECU possibly having a problem...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 11-03-2007, 12:44 PM
Re: No Spark?
Okay, I checked the three fuses in the mini box that have to do with ignition, they're all good, do you guys know of any other fuses to check, I don't know what's what because all the markings have been rubbed off the fuse box covers. Also, is there a definitive way to check for spark? I just pulled the wire off while we were cranking and saw no visible spark, I didn't know if that was a valid way to check or not. I'll try swapping ecu's and see if that helps at all. Thanks again.
1990 GSX
Old 11-03-2007, 11:07 PM
Re: No Spark?
Well, I'm beginning to suspect my CAS. The problem is that my chilton/haynes only give trouble shooting procedures for the 91-94, not the 90. Does anyone have test procedures for the 90 CAS? Thanks.
1990 GSX
Old 11-03-2007, 11:40 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: No Spark?
With my cam angle sensor unplugged the car will start and cut off immediately. Of course if you were talking about the crank sensor, if it were bad, it would definately cause a no spark situation.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 11-04-2007, 01:06 AM
Re: No Spark?
Wait a minute... I just realized something... Your cranking it with the spark plug boot off and just looking up in the boot for spark?...
If so... Uh, your not gonna see any because it doesn't work that way... You need to put a spark plug in the end of it while its out and touch the end of the spark plug to something bare metal to see if it sparks... Or you could just put your finger up there and turn it over. lol...
I guess I didn't think about the CAS being a possibility... It could be... But I think 90's ran a different one than other years?... Not quite sure on that one...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 11-04-2007, 07:50 AM
Re: No Spark?
Yeah, I figured out that I do have spark, I stuck a screw driver up the boot and grounded it as I cranked, so I have spark and fuel... I'm not sure where to go from there.
1990 GSX
Old 11-04-2007, 12:41 PM
Re: No Spark?
Timing off?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 11-04-2007, 01:07 PM
Re: No Spark?
I wouldn't think so, the car ran fine before we took the tranny off. I can't check the timing because I can't get the car to run.
1990 GSX
Old 11-04-2007, 01:09 PM
Re: No Spark?
I think we're going to pick up some new plugs and wires. I don't think that will change the situation because there didn't seem to be a problem with them beforehand, but they'll be cheap.
1990 GSX
Old 11-04-2007, 02:05 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: No Spark?
Did you unplug/break the CPS (crank position sensor) when you were fumbling around down there? Double check that you remembered to plug everything back in and make sure they are good connections.
95 Talon TSI AWD
97 Eclipse GST
