Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-02-2007, 10:19 PM
little79 little79 is offline
Hesitation
Can anybody figure this problem. I have 2001 1500 4X4 5.9L. if i give it to much gas it spits and sputters and there is no power. i have replaced plugs,wires, coil and even the fuel pump. no differance at all it still the same .... open for more suggestions. please
Old 11-08-2007, 12:45 PM
MXlonerider's Avatar
MXlonerider MXlonerider is offline
Send a message via AIM to MXlonerider Send a message via MSN to MXlonerider Send a message via Yahoo to MXlonerider
Re: Hesitation
Is the engine compartment getting fuel or no? Is it drowning or starving when it coughs? If it's not getting fuel, I'd say check your fuel filter for clogs, a lot of times there will be just enough flow through them for regular running but when you try to get that little extra flow, it can't get through. If you're getting too much fuel, I'd say check your codes first, there are a lot of possibilities. In fact, check your codes first either way to save a little money and rule things out.
Check out and rate my vehicles at My CarDomain
2000 Dodge Dakota, 4.7L V8 Auto 4x4 Club Cab Beauty
2002 Hyundai Sonata, I4 5 speed (Gone)
1988 Dodge D100 Pickup, 3.9L V6 Auto (Gone)
Old 12-27-2007, 01:34 PM
Re: Hesitation
Solved problem: turns out somewhere down the line the truck had a remote starter in it that was removed and the wire had not be attached properly cause the the fuel pump to cut in and out while driving form the vibrations.
