Go Back   Automotive Forums Car Chat > Cars/Parts for Sale/Exchange
Cars/Parts for Sale/Exchange Sell your car and parts or post what you are looking for.
Old 11-02-2007, 06:52 PM
professor9's Avatar
professor9 professor9 is offline
93 Grand Cherokee 4.0 For Sale Pittsburgh
1993 Grand Cherokee for sale north of Pittsburgh - Cranberry Township, PA. $1,250
The Jeep has 261,000 miles and I've owned it since fall of 1996.
Never been smoked in. Original engine and drivetrain.
Runs starts and drives good. Good tires. Doesn't vibrate, stall or shake.
Four wheel drive works fine.
New water pump, thermostat, hoses and motor mounts 10/07.
R134 serviced 8/07. AC works fair, which is above average for this model.
Recent starter, alternator and fuel pump.
Right front wheel bearing and ball joints January 2007.
Tranny fluid and filter changed summer 2005.
Normal engine oil leaks for this model - front crank seal, rear main seal, and oil filter housing. New O-rings for oil filter housing included with vehicle.
Body good - less than normal corrosion on door bottom flanges, rear hatch bottom flange and eft end of fender cavities. Corrosion always treated with phosphoric acid yearly. Dark green with gray interior.
Rear lamp failure message even though all lamps work. Normal message for these models.
Power windows all work but only work from driver's control.
AM/FM/CD works fine, but display doesn't work. Gotta search until you find the station you know. All speakers work fine. Aftermarket tweeters up front. Antenna drive broken - repair kit included with vehicle. Antenna mast bent.
Jeep has towing package. Hitch has internal corrosion. Pigtail works fine.
This Jeep has been a great, reliable vehicle for me for more than ten years. The only reason I am selling it is I am moving up to a newer vehicle.
This vehicle is located in Cranberry Township, PA, which is right off of Interstates 79 and 76. Those of you that know the Grand Cherokee know they are great vehicles. This one is ready for winter.
If you are interested in more information or would like pics, please do not hesitate to email me at [email protected]
Thanks
Prof
2012 Santa Fe
2013 Sonata
2005 Odyssey
The second ammendment means exactly what it says. The right of the people... shall not be infringed.
Many states have reinforcements to the 2nd ammendment - in that it shall not be questioned.
