Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 11-02-2007, 05:10 PM
Yajin Yajin is offline
Puting on altezza tailights(97 eclipse)
can anyone give me a little overview of how to put on altezza taillights on a 97 eclipse befor i got and take a part my car. i just unwraped them and i was looking in side of them and thier wasnt any bulbs do i just take out the old ones from the stock lights? HELP!!! PLS!
Thanks
-yajin
ops added 2 times
Old 11-02-2007, 05:59 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Puting on altezza tailights(97 eclipse)
The old bulbs should fit just fine. You have to take apart the 2 little coner pieces of the interior and then the big center plastic piece. There's probably like 6 nuts holding on each light. IIRC, you'll need a 10mm socket (and maybe a 12).
On the other hand, do us all a favor and leave those ugly ass taillights for the hondas. Stock > altezza.
Welcome to AF. Please read the rules and FAQ, and searching will get you along ways around here. Also be sure to add your car (year, model, mods) into your signature.
95 Talon TSI AWD
97 Eclipse GST
Old 11-02-2007, 06:13 PM
Thanks for the help man.
no way i think stock sucks.
I put my car year and model in my sig but i just got the car so thier arnt any mods as of right now =(
1997 Eclipse RS
-Chrome Altezza tail lights
-Apexi N1 Catback Exhaust system
-AEM V2 Cold Air Intake
-Alpine type-R speakers all the way around.
-Alpine V-Power MRP-550 4 Channel Amp
-Alpine iDA-x001 Deck
-Alpine V-Power MRP-M450 Amp
- 2 12'' dual subs
http://www.youtube.com/user/Hexed656 Vids of my car.
Old 11-02-2007, 06:15 PM
If anything, get the stock center piece painted to match the car, that doesn't make them look soo bad, but I still think they're way overplayed.
95 Talon TSI AWD
97 Eclipse GST
Old 11-02-2007, 06:21 PM
Yeah thats what i am doing gunna paint the stock center and only put altezza on the sides.
1997 Eclipse RS
- 2 12'' dual subs
Old 11-02-2007, 06:39 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-04-2007, 02:03 AM
Killa's Avatar
Killa Killa is offline
real talk , its gay
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 11-04-2007, 06:32 AM
ned032002's Avatar
ned032002 ned032002 is offline
Originally Posted by Killa
real talk , its gay
Hey killa don't beat around the bush or anything
As for the Altezzas, I am not a fan by any means but
Old 11-04-2007, 07:23 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
What type of paint do i get for the center piece? I was told I could not use the paint for the body of my car cause the center piece was not meta?
***EDIT***
Yeah I'm in the same boat as the others, don't do altezza man.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 11-04-2007, 07:34 PM
Any paint will work, but I'd use automotive paint, the stuff made for your car. Whoever told you that you couldn't is a retard, you don't paint directly to metal with it, it wouldn't stick. You'll need to scuff the light with some fine sandpaper, about 600 grit. Then lay down some adhesion promoter, I'd use Bulldog Adhesion Promoter, it comes in a spray can and works great. Then put down some primer, again, preferrably the same shit you use for your car, and then wetsand it "smooth" with 800-1000 grit, just be sure not to break through the primer very far, otherwise you'll have to re-coat that spot. Next put down a coat of sealer (automotive brands again), and lastly you can finally paint/clear. It's alot of work for such a small piece, but it has to be done if you want it to match the car and last a long time.
95 Talon TSI AWD
97 Eclipse GST
Old 11-04-2007, 07:35 PM
Holset powered 420a
You can use the same paint. Just scuff the taillight, primer it, wetsand it and, spray your base and clear coat.
*EDIT* - Damn beat me by 1 minute.
Also I wouldn't recommend sanding the primer with 1000 grit, I use 320, maybe 400 grit tops. If the primer gets to smooth the paint wont stick to the primer well.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-04-2007, 08:31 PM
JoeShmoe's Avatar
Damn that sounds like fun, i've never wet sanded before though. Any type of water for the wet sand?
Old 11-04-2007, 08:41 PM
Holset powered 420a
Yea, I usually get a hose and turn it on really low and let it run over the part I am sanding.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-04-2007, 10:02 PM
I was in a rush when I wrote that, yes 1000 is too smooth for primer, I meant to say on the sealer, like if you have a slight run or something, hit it with 800-1000 to get rid of the blemish. But 320-400 is way to rough of a final wetsand grit. You're supposed to start with 400 at the roughest, and that's on really high spots, and finish out with between 600-800, otherwise you'll be able to see the sanding marks through the sealer and primer.
95 Talon TSI AWD
97 Eclipse GST
Old 11-05-2007, 03:34 PM
JoeShmoe's Avatar
Right, yeah i got the sand paper. Just gotta remove those damn letters ECLIPSE. Hopefully i won't dig into the plastic.
