Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-02-2007, 05:04 PM
1992eclipseGS 1992eclipseGS is offline
Do Aftermarket Springs come with Alignment Specs??
Okay fellas, its time for drop before I send the car to its winter home (the garage).. I was told that a decent pair of lowering springs will come will the specs need to "Properly" align the car. I know I can centerline the car on the rack and go from there.. but having the proper specifications to put in the Computer makes it a hell of alot easier, So do springs come with spec sheets?/ and If so, what a springs have you guys bought that come with it, or didn't come with it??
1998 RS
5 speed, Stock front bumper w/molded urethane lip, Blitz side skirts, Bomex rear, JSP Carbon Fiber hood. Halo Projection Headlights, Escort radar detector, Turbo style spoiler, 1,200 watt sound system with 2 dual 12 subs, 20% executive tint, 17" sport rims, Custom built 2 1/2 Exhaust, OBX 4-1 Header, CAI, KYB GR-2 struts, Sprint lowering springs.
Old 11-02-2007, 06:09 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Do Aftermarket Springs come with Alignment Specs??
I don't get what you're saying. An alignment for a car should be the same. It shouldn't vary just because you put on different springs. The camber will change, but if you bring it to an alignment shop (with the correct camber kits installed), they should be able to bring it back to exact.
95 Talon TSI AWD
97 Eclipse GST
Old 11-03-2007, 07:12 PM
kjewer1 kjewer1 is offline
AF - Advisor
There is a good chance that you will want to avoid factory specs ona lowered car though for better tire wear. For example, setting front and rear toe to exactly zero.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-04-2007, 12:26 AM
I have the the alignment on my RS (which sits about 3" off the ground) set to stock and have had no trouble with tire wear.
95 Talon TSI AWD
97 Eclipse GST
Old 11-04-2007, 02:29 AM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
Ya when you do an alignment it doesnt matter what suspension you have in the car it just measure the wheel/tire relationship to the ground
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
