Old 11-02-2007, 10:34 AM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Fob Programming
I bought a #1 and #2 fob for my 2005 Silverado and I can program the #1 fob and the #1 fob that I got when I bought the truck but I can't program the #2 fob...is there something special I need to do? I checked the battery and it's good.
Old 11-04-2007, 07:41 AM
Sonny01's Avatar
Re: Fob Programming
Somebody must know something!
Old 11-04-2007, 03:00 PM
mcconnell45 mcconnell45 is offline
Re: Fob Programming
Sonny,
Had the same trouble when trying to program 2extra remotes to my truck, turns out I missed the step that you have to program all the remotes you have at the same time so the others won't ge erased. Heres the directions I followed just in case..maybe it will help
Transmitter Programming
TRANSMITTER PROGRAMMING
IMPORTANT: Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
There are 3 methods for programming transmitters which are listed below as method 1-3. Up to four transmitters may be programmed to the passenger door module (PDM). Each programmed transmitter is given a position of #1-#4 in the PDM memory.
Method 1 - No Tools Required, Program All Transmitters
IMPORTANT: All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds , the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
Operate the transmitter functions in order to verify correct system operation.
Method 2 - Scan Tool Required, Program Individual Transmitter Only use this option if you are certain which transmitter #1- #4 is being replaced, or the new transmitter can be programmed into a previously unused position within the PDM memory. Refer to IMPORTANT above.
Install a scan tool.
Turn the ignition ON, with the engine OFF.
Use the scan tool in order to access the passenger door module Special Function menu.
Select "Program Individual Key Fob" to program a specific transmitters.
Follow the directions on the scan tool in order to program the transmitter or transmitters.
Method 3 - Scan Tool Required, Program All Transmitters IMPORTANT: All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter. The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
Select "Program All Key Fobs" to clear the PDM memory.
2008 Silverado LTZ Z71 Extended Cab
"The Winner isn't the one with the fastest car, it's one who refuses to lose." #3
