Go Back   Automotive Forums Car Chat > Pontiac > 6000
Old 11-02-2007, 08:22 AM
canada110 canada110 is offline
1988 Pontiac 6000le wont start
Hey Guys,
the car has been running fine until oneday i took off at a stop sign and then it just died and i had to pull over.i went to start it and it just kept turning over and over but didn't start..so i got the car towed to a garage and then went there in the morning before they started to touch it and all of a sudden it started so i took it home drove it for the day and parked it..i went back to start it and nothing and has been dead now for couple days..any suggestions my brother did a spark test and thought it wasn't getting spark but iasked why all of a sudden it started and got spark and he was puzzled like me
any thoughts can you please email me if you can at [email protected] if you have time as i won't be checking this site to often other than my emails on my phone..
thank you to all who read and help in advance...
T
Old 06-30-2013, 12:59 AM
royengle royengle is offline
Re: 1988 Pontiac 6000le wont start
Originally Posted by My Sixth Gear
I encountered a similar problem with the 3100 where the cylinder six fuel injector was shorted and only had a 1 ohm resistance value, this caused all the current to go this injector and the other two injectors on the same bank weren't firing causing the engine to stall. Try checking the resistance values of the injectors, all should be around 6 or so ohms.
