Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-02-2007, 01:21 AM
camaroguy149 camaroguy149 is offline
a/c problems
hey i hav 97 camaro. the a/c isnt that cold, it only blows underneath near feet. not to head or above. wat is that, a fuse or something? is chanoing a fuel filter hard on these cars, its easy on my truck
Old 11-02-2007, 11:40 AM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
Re: a/c problems
well your ac may just need to be recharged..you can buy a kit at local hardware store for less then 20$ i dont know about why it only blows on feet thought..also fuel filter was real easy to do on my 2000 trans am..its located under the car near the driver side rear tire area..takes less then 10 mins to do..and also is under 10$..hope that helps you
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm summit throttle body
85mm bbk ssi intake
fast fuel rails
30lb ford racing injectors
spohn strut bar
msd ignition coils
msd 8.5mm spark plug wires
edelbrock shorty headers
upgrade cam/ port and polished heads
SMG dyno tuned ( 375 rear wheel hp )
magnaflow cat back
slp y pipe
umi bolt on subframe connectors
umi rear control arms
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 11-02-2007, 10:42 PM
CamaroRS92 CamaroRS92 is offline
Re: a/c problems
your A/C is likely fine. By your description it sounds like the blend doors are malfunctioning and is diverting the air flow thru the heater core instead of the A/C evaporator core
Have those checked out first to see if they are stuck or may need a vacuum actuator replaced. The problem can also be within the A/C - Heat Vacuum selector switch possibly broken or does not have a vacuum supply present at the switch
