Go Back   Automotive Forums Car Chat > Buick > Century
Old 11-01-2007, 10:19 PM
rnj rnj is offline
Send a message via MSN to rnj
transmission question, rattling at startup
1995 century 3.1 104000. What does "automatic transmission pump starvation or cavitation, or a sticking pressure-regulator valve" mean. Is this something that can be remedied through fluid and filter change? The car runs fine shifts between 1-2 seems a little long, but it doesn't slam into any gears.
Old 11-02-2007, 05:46 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: transmission question, rattling at startup
fluid cavitation/starvatin means the pump sucked air instead of fluid. This could be caused by a blocked filter or low fluid level. Try changing the filter and the fluid that is drained from the pan (DO NOT do a flush/total fluid exchange at your car's age/mileage) and put a can of Trans-X or Seafoam trans treatment in. Also, check the vacuum line to the trans modulator for the presence of fluid. IF there is fluid present, the diaphram is split and you need a new shift modulator. This would explain the long/slow 1-2 shift (especially at part throttle shifts) and the loss of fluid. If this doesn't help, then you probably need some internal trans work.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-02-2007, 08:03 AM
rnj rnj is offline
thanks for the reply. I had planned on doing filter/fluid change this weekend in hopes of clogged filter being the problem. didn't know seafoam had trans. treatment. Thank You!
