I have a Honda Accord Lx 2001, 4cyl, automatic with 110,00 miles on it. My car have a vibration around 60mph to 70mph anything before that feels really good. I notice that is less when I let go the gas pedal. Car has a new transmition installed by the dealer because shifting problems, the front wheel bearings where replaced, and I put the front rotors because a pulsation at hard stops. Yesterday I put new rims and four new tires. I took the car for aligment and I was inspected and toe was adjusted to the right specs. The vibration was there before any of this was done really bad, now is problably 40% of what it was, but steel there. I coud feel it on the body of the car, a little bit on the sterring wheel and on the transmition shifter. Any imput will be greatly apreciated after all I have done. I don't know what else to do. Oh one more thing to mention, I notice the hub assembly turning out of round with out the tire and the rotors, and the axle shaft like woboling as it turns on the inner cv joint. Help me!!!!!!!!
Re: One or the Other????
Sounds like one of the CV shafts didn't get fully seated into the tranny...take it back before it self-destructs...which it will, if fluttering off-center...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
Actually, re-reading it sounds like you have a bent splined stub on the outboard side, or the stub isn't fully seated in the hub bearing...either way I think you need that axle looked at closely...
Thank you for your imput on this matter. I will the mechanic look at it.
