Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 11-01-2007, 07:36 PM
BigRed BigRed is offline
02 2.4L SOHC Timing Belt replacement
Is there a link or dose any know any tips on replacing a timing belt on a 2.4 SOHC 2002 Galant
Old 11-07-2007, 07:34 PM
Re: 02 2.4L SOHC Timing Belt replacement
OK just finished 2.4 timing belt and balancer belt. I could not find a plug or hole in the side of the engine to insert a #3 Phillips head screw driver so the balancing shaft wont move. I could not get the main bolt loose so I worked the new belt onto the balancing pully. BE CAREFUL and REMOVE the crancase sensor so not to break it like I did for and extra $130 and 3 extra hours work. I did use the Haynes manual and it had bad information about this job.
