Go Back   Automotive Forums Car Chat > Buick > Riviera
Old 11-01-2007, 04:58 PM
96Rivman 96Rivman is offline
DTC 1406 code valve pintle?
Just wondering if I can pick a few brains here. I have a SES light what seems to be a bad egr valve on my 96' with 155K. So I swapped it out with a different one and I still have a SES light on. Has anyone ever dealt with this problem and if so how do I remedy it? Thanks
Old 11-01-2007, 08:03 PM
maxwedge maxwedge is offline
A990 racer
Re: DTC 1406 code valve pintle?
These are the parameters that set that code, http://service.gm.com/gmspo/mode6/pd...c38K_C__yE.pdf A bi-directional scanner can command the egr and confirm it's operation, did you put on a known good one? Did you clear the code and it returned?
Old 11-02-2007, 09:05 AM
That's the only problem, I am not sure if the egr is a known good one. I don't have access to a scanner like the one you are talking about. Is there anything else that would set a code P1406? How about a bad o2 sensor.
Old 11-06-2007, 01:45 PM
roylwchez roylwchez is offline
i got the same code cleared it and its coming back as pending i am going to drive the car around for a while and see if it come back. scanners for can be found at walmart for 100$ they read and clear the codes work great
Old 11-06-2007, 07:31 PM
It doesn't do any good to clear the code without fixing the problem. Maxwedge is talking about a scanner that the repair shops/dealers use and you ain't getting one of those for $100. I know what the problem is I am just trying to troubleshoot before going out and buying a new egr valve. They are $150!
Old 11-23-2007, 01:12 PM
Just wondering if anyone knows how to test/ohm out a egr valve off the vehicle. I need to confirm that's bad before going out and buying one. Thanks
