Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-01-2007, 03:34 PM
airFS airFS is offline
boost gauge wiring 2g
I basically need an idiots guide on how to wire my boost gauge. I have the vaccume lines figured out, but I cant seem to find or locate what wires to cut and put where. Please help me!
96' Talon tsi AWD
Mods: greddy upper and lower intercooler pipes _ greddy type rs bov _ K&N intake _ 3" turbo back exhaust _ ngk spark plugs & wires _ garrett T-28 turbo _ greddy oil catch tank
Old 11-01-2007, 03:42 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: boost gauge wiring 2g
http://my.prostreetonline.com/t99.htm
95 Talon TSI AWD
97 Eclipse GST
Old 11-01-2007, 03:55 PM
Thank you kindly
96' Talon tsi AWD
Old 11-01-2007, 03:57 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Thats a good write up, but why did he run the 12v wire all the way down beside the seat. I tapped into the wire behind my gauges, or you could use the dimmer switch and it would be a much shorter wire.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-01-2007, 06:21 PM
I think the dimmer switch idea is the best, because then you can fade your gauges in and out with the rest of the interior, as for why he used the taillight wire, I have no idea.
If you want to tap into the dimmer switch, read here.
http://www.vfaq.com/mods/gaugelit.html
95 Talon TSI AWD
97 Eclipse GST
Old 11-01-2007, 09:05 PM
Will the 1g's be the same as a 2g's
96' Talon tsi AWD
Old 11-01-2007, 09:53 PM
Holset powered 420a
For the most part. The only problem is that the gauges use led lights so they wont dim very much. On the plus side thats less current drawn by the gauge so you dont have to worry about over loading the circuit.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-01-2007, 10:02 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I say fuck the dimmer switch, how often do you use it? I'm still going to do it that way, but I think its retarded that there is even one.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
