Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 11-01-2007, 08:45 AM
mrmartin23's Avatar
mrmartin23 mrmartin23 is offline
Cooling fan test
I would like to check if my cooling fans are comming on. What is the tricks to checking when/if they come on. Is there a temp setting or do they stay on all the time?
Thanks all
<--------Needs more coffee
Full time dad to 2, wife of 16yrs, San Diego Chargers fan, Formula-1 project and commander of my paintball group------- yeah i'm busy .
Old 11-01-2007, 09:01 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Cooling fan test
The primary fan should come on around 220-230 avgerage and go off at 200-205 ish.
The secondary fan is on mainly when the A/C is in use.
Old 11-01-2007, 01:04 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
yeah secondary depends on the a/c being on and what speed you are going. if you want to test the primary just ground the temp switch wire that is on the right side (passenger) head.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 11-07-2007, 12:09 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
you can also jump the cooling fan relay on the driver side firewall, however, if you get it wrong, and jump the fuel pump relay (speaking from experience), youll blow the fuel pump fuse that is at the end of a harness pigtail over by the radiator overflow tank. just a heads up on that. i wound up getting my car towed because of a blown fuse i couldnt find. i got laughed at for a week at the shop for that one.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
