Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 10-31-2007, 11:16 PM
tjr19136 tjr19136 is offline
1994 Continental not going over 40 MPH
My 1994 Lincoln Continental will not go over 40 MPH...
What are some problems that can cause this issue........
Old 11-18-2007, 08:32 PM
ringo7 ringo7 is offline
Re: 1994 Continental not going over 40 MPH
Has any thing happened to car like overtemp or Trans fluid change;
Sound s like it is in a self protect mode
Old 11-18-2007, 09:11 PM
HotRodCourier's Avatar
HotRodCourier HotRodCourier is offline
It sounds like your car is in limp home mode. My guess is that it may have lost tach signal to your EDIS module (I'm pretty sure you car is equipped with EDIS) without tach it wont advance the spark and esentually retards the spark at RPM. of course the computer could be causing to function like this due to some other error.
Go get it scanned If all looks well I would start looking at the fuel side. Perhaps a bad presure regulator is letting the line pressure drop to low or it could be something as simple as a plugged fuel filter or weak pump.
If Couriers were tomatos the green ones wouldn't be ripe.
www.hotrodcourier.com
Old 02-14-2008, 12:36 AM
bcr220 bcr220 is offline
im having the same problem in a 1995 cont. i try to punch the gas once it goes over 4000 rpm over 40mph it stalls out kinda, hesitates and acts funny, dont know if this is ur problem too but if u find anything please let me know2
Old 04-15-2008, 07:22 PM
GQMFSmooth GQMFSmooth is offline
i had this same peoblem on my 95 cont turned out to be the power train relay in the fuse block under the hood only cost 6$ i think but once i hit 40mph the traction controll would kick on and limit me to only 40 and i could not give it more gas till it dropped to 30-35 mph
hope this helps
