Old 10-31-2007, 09:38 PM
NoRiceHere01 NoRiceHere01 is offline
Startup issue
Can anyone explain why its been taking longer and longer for my truck to start? I noticed a few months back that it seemed to turn over a little longer than usual before staring.Now tho it almost never starts the first time the key is turned. It did light right up the second time i bumped it, but now it sometimes takes 3 or even 4 turns of the key.I have replaced the fuel pump, but naturally not with a factory unit, which i now understand to be the only real way to do it.Is the problem maybe a result of a weak pump?i cant seem to understand it,and i like to flatter myself a pretty good mechanic.i also replaced the pressure regulator and filter.
Old 11-01-2007, 08:03 AM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Re: Startup issue
Did you do a fuel preasure test?
Have you looked at your plugs and wires lately?
It could be the starter coils too.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 11-01-2007, 10:07 AM
rjeffery rjeffery is offline
Re: Startup issue
It does sound like a bad fuel pump or fpr. Do a fuel pressure test to confirm.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
